Jira Index Failure on Issue Create, Project Re-index , Re-index
Mümin Can Yılmaz
July 9, 2019
I have a Jira v7.13 on a windows host. I cannot reindex my jira and when i try to create an issue; i get error saying this :
I stoped Jira and deleted ..\JIRA_HOME\cachs\indexes directory, so Jıra can re-create the files. But the problem wansn't fix. Here's my logs when i try to create an issue :
2019-07-09 17:24:30,658 http-nio-8080-exec-4 WARN api.admin 1044x3064x1 hp0f3m 82.151.139.254 /secure/CreateIssueDetails.jspa [c.a.jira.index.AccumulatingResultBuilder] Indexing failed for Issue - '13505'
2019-07-09 17:24:30,658 http-nio-8080-exec-4 WARN api.admin 1044x3064x1 hp0f3m 82.151.139.254 /secure/CreateIssueDetails.jspa [c.a.jira.index.AccumulatingResultBuilder] com.atlassian.jira.jql.parser.JqlParseException: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException: org.antlr.runtime.RecognitionException
java.lang.RuntimeException: com.atlassian.jira.jql.parser.JqlParseException: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException: org.antlr.runtime.RecognitionException
at com.atlassian.jira.index.DefaultIndex$Failure.<init>(DefaultIndex.java:101)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$reindexIssues$1(DefaultIssueIndexer.java:217)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$null$2(DefaultIssueIndexer.java:337)
at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:7)
at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:5)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$perform$3(DefaultIssueIndexer.java:335)
at com.atlassian.jira.util.collect.CollectionUtil.foreach(CollectionUtil.java:39)
at com.atlassian.jira.util.collect.CollectionUtil.foreach(CollectionUtil.java:52)
at com.atlassian.jira.issue.util.IssueObjectIssuesIterable.foreach(IssueObjectIssuesIterable.java:24)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.perform(DefaultIssueIndexer.java:307)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.reindexIssues(DefaultIssueIndexer.java:187)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssues(DefaultIndexManager.java:594)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssueObjects(DefaultIndexManager.java:469)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndex(DefaultIndexManager.java:513)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndex(DefaultIndexManager.java:497)
... 3 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.jira.config.component.SwitchingInvocationHandler.invoke(SwitchingInvocationHandler.java:38)
at com.sun.proxy.$Proxy12.reIndex(Unknown Source)
at com.atlassian.jira.workflow.function.issue.IssueReindexFunction.execute(IssueReindexFunction.java:23)
at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1014)
at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1407)
at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:606)
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:742)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:584)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:498)
at com.atlassian.jira.issue.managers.RequestCachingIssueManager.createIssue(RequestCachingIssueManager.java:192)
at com.atlassian.jira.bc.issue.DefaultIssueService.create(DefaultIssueService.java:238)
at com.atlassian.jira.web.action.issue.CreateIssueDetails.createIssue(CreateIssueDetails.java:99)
at com.atlassian.jira.web.action.issue.CreateIssueDetails.doExecute(CreateIssueDetails.java:78)
... 1 filtered
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
... 7 filtered
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
... 15 filtered
at com.softwareplant.ppm.structureint.jiraserver.event.PluginIssueLinkListener.doFilter(PluginIssueLinkListener.java:86)
... 3 filtered
at com.idalko.jira.plugins.igrid.WebResourceIncludeFilter.doFilter(WebResourceIncludeFilter.java:166)
... 36 filtered
at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:56)
... 4 filtered
at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:62)
... 12 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 20 filtered
at com.intenso.jira.plugin.customfield.dynamicselect.util.contentinjection.filter.ContentInjectionFilter.doFilter(ContentInjectionFilter.java:35)
... 41 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 39 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 5 filtered
at com.idalko.jira.plugins.igrid.servicedesk.ServletRequestContextFilter.doFilter(ServletRequestContextFilter.java:23)
... 3 filtered
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:181)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ReentrantThreadLocalBasedCodeContext.java:137)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(ReentrantThreadLocalBasedCodeContext.java:90)
at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(CustomerContextServiceImpl.java:47)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:174)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:130)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:121)
... 4 filtered
at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:32)
... 8 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 25 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Caused by: com.atlassian.jira.jql.parser.JqlParseException: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException: org.antlr.runtime.RecognitionException
at com.atlassian.jira.jql.parser.DefaultJqlQueryParser.parseClause(DefaultJqlQueryParser.java:110)
at com.atlassian.jira.jql.parser.DefaultJqlQueryParser.parseQuery(DefaultJqlQueryParser.java:33)
at com.atlassian.jira.jql.parser.JqlQueryParser$parseQuery$0.call(Unknown Source)
at com.onresolve.jira.groovy.jql.AbstractScriptedJqlFunction.search(AbstractScriptedJqlFunction.groovy:171)
at com.onresolve.jira.groovy.jql.AbstractScriptedJqlFunction$search.callCurrent(Unknown Source)
at com.onresolve.jira.groovy.jql.relations.RelationsOfMatchingQuery$getQuery.call(Unknown Source)
at com.onresolve.jira.groovy.jql.ScriptedJqlFunction.getQuery(ScriptedJqlFunction.groovy:128)
at com.onresolve.jira.groovy.jql.ScriptedJqlFunction$getQuery.call(Unknown Source)
at com.onresolve.jira.groovy.jql.ScriptedFunctionClauseFactory.getQuery(ScriptedFunctionClauseFactory.groovy:92)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:97)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:25)
at com.atlassian.query.clause.TerminalClauseImpl.accept(TerminalClauseImpl.java:143)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:55)
at com.atlassian.query.clause.AndClause.accept(AndClause.java:28)
at com.atlassian.jira.jql.query.QueryVisitor.createQuery(QueryVisitor.java:51)
at com.atlassian.jira.jql.query.DefaultLuceneQueryBuilder.createLuceneQuery(DefaultLuceneQueryBuilder.java:29)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.createLuceneQuery(LuceneSearchProvider.java:359)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.getHits(LuceneSearchProvider.java:238)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.search(LuceneSearchProvider.java:393)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.search(LuceneSearchProvider.java:128)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.search(LuceneSearchProvider.java:124)
at com.atlassian.jira.bc.issue.search.DefaultSearchService.search(DefaultSearchService.java:111)
at tr.com.obss.selectissue.plugin.api.Jira7FieldValueManager.getSearchResults(Jira7FieldValueManager.java:73)
at tr.com.obss.selectissue.plugin.util.Utils.findIssue(Utils.java:98)
at tr.com.obss.selectissue.plugin.util.CustomFieldUtils.returnSearchList(CustomFieldUtils.java:59)
at tr.com.obss.selectissue.plugin.util.CustomFieldUtils.fetchJQLQueryResultsForSearch(CustomFieldUtils.java:152)
at tr.com.obss.selectissue.plugin.searcher.JQLSearchIndexerForView.addDocumentFieldsSearchable(JQLSearchIndexerForView.java:40)
at com.atlassian.jira.issue.index.indexers.impl.AbstractCustomFieldIndexer.addIndex(AbstractCustomFieldIndexer.java:40)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory$Builder.add(DefaultIssueDocumentFactory.java:90)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory$Builder.addAll(DefaultIssueDocumentFactory.java:81)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory.apply(DefaultIssueDocumentFactory.java:51)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory.apply(DefaultIssueDocumentFactory.java:31)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$DefaultDocumentCreationStrategy.get(DefaultIssueIndexer.java:590)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$reindexIssues$1(DefaultIssueIndexer.java:191)
... 311 more
Caused by: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException: org.antlr.runtime.RecognitionException
at com.atlassian.jira.jql.parser.antlr.JqlParser.reportError(JqlParser.java:203)
at com.atlassian.jira.jql.parser.antlr.JqlParser.terminalClause(JqlParser.java:761)
at com.atlassian.jira.jql.parser.antlr.JqlParser.notClause(JqlParser.java:555)
at com.atlassian.jira.jql.parser.antlr.JqlParser.andClause(JqlParser.java:432)
at com.atlassian.jira.jql.parser.antlr.JqlParser.orClause(JqlParser.java:366)
at com.atlassian.jira.jql.parser.antlr.JqlParser.query(JqlParser.java:237)
at com.atlassian.jira.jql.parser.DefaultJqlQueryParser.parseClause(DefaultJqlQueryParser.java:103)
... 346 more
Caused by: org.antlr.runtime.RecognitionException
at com.atlassian.jira.jql.parser.antlr.JqlParser.terminalClause(JqlParser.java:760)
... 352 more
2019-07-09 17:24:30,668 http-nio-8080-exec-4 ERROR api.admin 1044x3064x1 hp0f3m 82.151.139.254 /secure/CreateIssueDetails.jspa [c.a.j.bc.issue.DefaultIssueService] Error creating issue:
com.atlassian.jira.exception.CreateException: Indexing completed with 1 errors
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:592)
... 1 filtered
... 7 filtered
... 15 filtered
... 3 filtered
... 36 filtered
... 4 filtered
... 12 filtered
... 20 filtered
... 41 filtered
... 1 filtered
... 39 filtered
... 5 filtered
... 3 filtered
... 4 filtered
... 8 filtered
... 4 filtered
... 26 filtered
... 25 filtered
Caused by: com.atlassian.jira.workflow.WorkflowException: Indexing completed with 1 errors
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:768)
... 286 more
Caused by: com.atlassian.jira.index.IndexingFailureException: Indexing completed with 1 errors
at com.atlassian.jira.index.AccumulatingResultBuilder$CompositeResult.await(AccumulatingResultBuilder.java:187)
at com.atlassian.jira.issue.index.DefaultIndexManager.await(DefaultIndexManager.java:828)
... 3 filtered
... 287 more
Ananias Gutierrez
April 26, 2023
como lo resolviste ?
