Celebration
Earn badges and make progress
Deleted user Avatar
Deleted user
Level 1: Seed
25 / 150 points
Next: Root
Avatar
1 badge earned
Collect
Participate in fun challenges
Challenges
Coins
Gift kudos to your peers
Recognition
Ribbon
Rise up in the ranks
Leaderboard
Come for the products,
stay for the community
The Atlassian Community can help you and your team get more value out of Atlassian products and practices.
Atlassian Community about banner
4,556,502
Community Members
Community Events
184
Jira Index Failure on Issue Create, Project Re-index , Re-index
I have a Jira v7.13 on a windows host. I cannot reindex my jira and when i try to create an issue; i get error saying this :
I stoped Jira and deleted ..\JIRA_HOME\cachs\indexes directory, so Jıra can re-create the files. But the problem wansn't fix. Here's my logs when i try to create an issue :
2019-07-09 17:24:30,658 http-nio-8080-exec-4 WARN api.admin 1044x3064x1 hp0f3m 82.151.139.254 /secure/CreateIssueDetails.jspa [c.a.jira.index.AccumulatingResultBuilder] Indexing failed for Issue - '13505'
2019-07-09 17:24:30,658 http-nio-8080-exec-4 WARN api.admin 1044x3064x1 hp0f3m 82.151.139.254 /secure/CreateIssueDetails.jspa [c.a.jira.index.AccumulatingResultBuilder] com.atlassian.jira.jql.parser.JqlParseException: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException: org.antlr.runtime.RecognitionException
java.lang.RuntimeException: com.atlassian.jira.jql.parser.JqlParseException: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException: org.antlr.runtime.RecognitionException
at com.atlassian.jira.index.DefaultIndex$Failure.<init>(DefaultIndex.java:101)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$reindexIssues$1(DefaultIssueIndexer.java:217)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$null$2(DefaultIssueIndexer.java:337)
at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:7)
at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:5)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$perform$3(DefaultIssueIndexer.java:335)
at com.atlassian.jira.util.collect.CollectionUtil.foreach(CollectionUtil.java:39)
at com.atlassian.jira.util.collect.CollectionUtil.foreach(CollectionUtil.java:52)
at com.atlassian.jira.issue.util.IssueObjectIssuesIterable.foreach(IssueObjectIssuesIterable.java:24)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.perform(DefaultIssueIndexer.java:307)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.reindexIssues(DefaultIssueIndexer.java:187)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssues(DefaultIndexManager.java:594)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssueObjects(DefaultIndexManager.java:469)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndex(DefaultIndexManager.java:513)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndex(DefaultIndexManager.java:497)
... 3 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.jira.config.component.SwitchingInvocationHandler.invoke(SwitchingInvocationHandler.java:38)
at com.sun.proxy.$Proxy12.reIndex(Unknown Source)
at com.atlassian.jira.workflow.function.issue.IssueReindexFunction.execute(IssueReindexFunction.java:23)
at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1014)
at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1407)
at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:606)
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:742)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:584)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:498)
at com.atlassian.jira.issue.managers.RequestCachingIssueManager.createIssue(RequestCachingIssueManager.java:192)
at com.atlassian.jira.bc.issue.DefaultIssueService.create(DefaultIssueService.java:238)
at com.atlassian.jira.web.action.issue.CreateIssueDetails.createIssue(CreateIssueDetails.java:99)
at com.atlassian.jira.web.action.issue.CreateIssueDetails.doExecute(CreateIssueDetails.java:78)
... 1 filtered
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
... 7 filtered
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
... 15 filtered
at com.softwareplant.ppm.structureint.jiraserver.event.PluginIssueLinkListener.doFilter(PluginIssueLinkListener.java:86)
... 3 filtered
at com.idalko.jira.plugins.igrid.WebResourceIncludeFilter.doFilter(WebResourceIncludeFilter.java:166)
... 36 filtered
at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:56)
... 4 filtered
at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:62)
... 12 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 20 filtered
at com.intenso.jira.plugin.customfield.dynamicselect.util.contentinjection.filter.ContentInjectionFilter.doFilter(ContentInjectionFilter.java:35)
... 41 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 39 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 5 filtered
at com.idalko.jira.plugins.igrid.servicedesk.ServletRequestContextFilter.doFilter(ServletRequestContextFilter.java:23)
... 3 filtered
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:181)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ReentrantThreadLocalBasedCodeContext.java:137)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(ReentrantThreadLocalBasedCodeContext.java:90)
at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(CustomerContextServiceImpl.java:47)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:174)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:130)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:121)
... 4 filtered
at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:32)
... 8 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 25 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Caused by: com.atlassian.jira.jql.parser.JqlParseException: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException: org.antlr.runtime.RecognitionException
at com.atlassian.jira.jql.parser.DefaultJqlQueryParser.parseClause(DefaultJqlQueryParser.java:110)
at com.atlassian.jira.jql.parser.DefaultJqlQueryParser.parseQuery(DefaultJqlQueryParser.java:33)
at com.atlassian.jira.jql.parser.JqlQueryParser$parseQuery$0.call(Unknown Source)
at com.onresolve.jira.groovy.jql.AbstractScriptedJqlFunction.search(AbstractScriptedJqlFunction.groovy:171)
at com.onresolve.jira.groovy.jql.AbstractScriptedJqlFunction$search.callCurrent(Unknown Source)
at com.onresolve.jira.groovy.jql.relations.RelationsOfMatchingQuery$getQuery.call(Unknown Source)
at com.onresolve.jira.groovy.jql.ScriptedJqlFunction.getQuery(ScriptedJqlFunction.groovy:128)
at com.onresolve.jira.groovy.jql.ScriptedJqlFunction$getQuery.call(Unknown Source)
at com.onresolve.jira.groovy.jql.ScriptedFunctionClauseFactory.getQuery(ScriptedFunctionClauseFactory.groovy:92)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:97)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:25)
at com.atlassian.query.clause.TerminalClauseImpl.accept(TerminalClauseImpl.java:143)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:55)
at com.atlassian.query.clause.AndClause.accept(AndClause.java:28)
at com.atlassian.jira.jql.query.QueryVisitor.createQuery(QueryVisitor.java:51)
at com.atlassian.jira.jql.query.DefaultLuceneQueryBuilder.createLuceneQuery(DefaultLuceneQueryBuilder.java:29)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.createLuceneQuery(LuceneSearchProvider.java:359)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.getHits(LuceneSearchProvider.java:238)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.search(LuceneSearchProvider.java:393)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.search(LuceneSearchProvider.java:128)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.search(LuceneSearchProvider.java:124)
at com.atlassian.jira.bc.issue.search.DefaultSearchService.search(DefaultSearchService.java:111)
at tr.com.obss.selectissue.plugin.api.Jira7FieldValueManager.getSearchResults(Jira7FieldValueManager.java:73)
at tr.com.obss.selectissue.plugin.util.Utils.findIssue(Utils.java:98)
at tr.com.obss.selectissue.plugin.util.CustomFieldUtils.returnSearchList(CustomFieldUtils.java:59)
at tr.com.obss.selectissue.plugin.util.CustomFieldUtils.fetchJQLQueryResultsForSearch(CustomFieldUtils.java:152)
at tr.com.obss.selectissue.plugin.searcher.JQLSearchIndexerForView.addDocumentFieldsSearchable(JQLSearchIndexerForView.java:40)
at com.atlassian.jira.issue.index.indexers.impl.AbstractCustomFieldIndexer.addIndex(AbstractCustomFieldIndexer.java:40)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory$Builder.add(DefaultIssueDocumentFactory.java:90)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory$Builder.addAll(DefaultIssueDocumentFactory.java:81)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory.apply(DefaultIssueDocumentFactory.java:51)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory.apply(DefaultIssueDocumentFactory.java:31)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$DefaultDocumentCreationStrategy.get(DefaultIssueIndexer.java:590)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$reindexIssues$1(DefaultIssueIndexer.java:191)
... 311 more
Caused by: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException: org.antlr.runtime.RecognitionException
at com.atlassian.jira.jql.parser.antlr.JqlParser.reportError(JqlParser.java:203)
at com.atlassian.jira.jql.parser.antlr.JqlParser.terminalClause(JqlParser.java:761)
at com.atlassian.jira.jql.parser.antlr.JqlParser.notClause(JqlParser.java:555)
at com.atlassian.jira.jql.parser.antlr.JqlParser.andClause(JqlParser.java:432)
at com.atlassian.jira.jql.parser.antlr.JqlParser.orClause(JqlParser.java:366)
at com.atlassian.jira.jql.parser.antlr.JqlParser.query(JqlParser.java:237)
at com.atlassian.jira.jql.parser.DefaultJqlQueryParser.parseClause(DefaultJqlQueryParser.java:103)
... 346 more
Caused by: org.antlr.runtime.RecognitionException
at com.atlassian.jira.jql.parser.antlr.JqlParser.terminalClause(JqlParser.java:760)
... 352 more
2019-07-09 17:24:30,668 http-nio-8080-exec-4 ERROR api.admin 1044x3064x1 hp0f3m 82.151.139.254 /secure/CreateIssueDetails.jspa [c.a.j.bc.issue.DefaultIssueService] Error creating issue:
com.atlassian.jira.exception.CreateException: Indexing completed with 1 errors
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:592)
... 1 filtered
... 7 filtered
... 15 filtered
... 3 filtered
... 36 filtered
... 4 filtered
... 12 filtered
... 20 filtered
... 41 filtered
... 1 filtered
... 39 filtered
... 5 filtered
... 3 filtered
... 4 filtered
... 8 filtered
... 4 filtered
... 26 filtered
... 25 filtered
Caused by: com.atlassian.jira.workflow.WorkflowException: Indexing completed with 1 errors
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:768)
... 286 more
Caused by: com.atlassian.jira.index.IndexingFailureException: Indexing completed with 1 errors
at com.atlassian.jira.index.AccumulatingResultBuilder$CompositeResult.await(AccumulatingResultBuilder.java:187)
at com.atlassian.jira.issue.index.DefaultIndexManager.await(DefaultIndexManager.java:828)
... 3 filtered
... 287 more
como lo resolviste ?
