I have created a script which should create an issue. Target WF has validators on the create screen and I receive error "Field X is required". Validator come from Suite Uilities. I'm setting Field X via custom_field_mappings but it looks like they are used after validators stage. Anyone successfully created an issue with validators enabled using SIL?
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!Online forums and learning are now in one easy-to-use experience.
By continuing, you accept the updated Community Terms of Use and acknowledge the Privacy Policy. Your public name, photo, and achievements may be publicly visible and available in search engines.
