I’d like to set up an automation rule in Jira that sends an email notification using aws sns every time a new issue is created and appears on a specific Jira dashboard. I’m not sure how to configure this using Jira Automation.
Related here, you can send the dashboard itself in an email, as well! It may be a viable alternative to solve your use case.
This is how it looks in your email client:
... and then in the PDF:
Links:
(Discl. this app is developed by our team.)
Hello @PATEL,VRAJ
Have you seen this documentation?
https://support.atlassian.com/cloud-automation/docs/configure-aws-sns-for-jira-automation/
@Trudy P Claspill is there a reason the key-value pairs are nested inside the `automationData` field? Is it possible to not do this?
"Type" : "Notification",
"MessageId" : "471b515d-50c5-5fc1-838a-30260807b93b",
"TopicArn" : "arn:aws:sns:us-west-2:",
"Message" : "{\"automationData\":{\"test_field\":\"test_value\"}}",
Hello @Kelly Bilodeau
I am just another user of the Atlassian products, not a developer of them or an Atlassian Team Member. I have no information on why it or AWS was developed the way it was. Nor do I have any actual experience with the AWS SNS integration. You could try contacting the Atlassian or AWS support team for more details.
