Need help with JIRA Project Automation
Aisha M
I am trying to clear two date field values when an issue (Epic) moves back to certain statuses.
Can someone please help with the steps to achieve this, I'm fairly new to JIRA Automation.
Thank you !
Iago Docando
July 15, 2020
It seems fairly simple. You'll need 3 steps:
  1. TRIGGER. Issue transition. From your status A to status B
  2. JQL FILTER. issuetype = epic (or epics within a specific project. whatever you need)
  3. ACTION. Edit issue fields. select your fields and leave them blank
Hope it helps.
Aisha M
@Iago Docando Thank you for the reply. It worked fine :)
Like Iago Docando likes this
