I'm trying to trigger an automation when a comment is added to a work item/Jira issue, but the rule never fires. What I've tested so far:
Hello @Kartik Verma
What I am asking myself here is why you did not use the built-in Work item commented / Issue commented trigger instead ?
Best,
Arkadiusz🤠
@Arkadiusz Wroblewski That was my first thought but apparently, Work Item commented is not an option trigger.
So it´s definitely Studio.
Studio currently has limited product/trigger coverage.
Field value changed Comment is not really a reliable substitute for the comment trigger.
[UPDATE] I found the way,
1. Select "Multiple Work Item events" trigger
2. Check only "Work item updated"
3. Add condition, select "{{smart values}} condition"
4. First value: {{changelog.comment}}
5. Condition: "is not empty" or "contains"
6. Second value: Leave blank or enter any text
Hi @Kar,
I’m Thiago from the Appfire team.
In the Jira framework, comments are handled via separate event streams rather than standard field updates, which is why your "Field value changed" and "Work item updated" triggers aren't catching them.
If you're open to looking at alternative apps to solve this, JMWE (Jira Misc Workflow Extensions) handles this exact scenario seamlessly through its own Event-based Actions feature.
As you can see in the example below, it's incredibly straightforward to set up:
You can easily create an action triggered specifically by issue comments with just a few clicks, apply it to whichever projects you want, and even use JQL or Nunjucks scripting if you ever need to add complex filters later on.
If you decide to give it a try and run into any questions while setting it up, feel free to reach out to our support team. We'd be happy to help!
Best regards,
Appfire Support Team
Welcome to the community.
Jira rules, always has this option to trigger based on comment.
What steps did you take, as your screenshot is not a view I can get? Do you have Rovo DEV and is it relarted to this?
I am using the Rovo Studio, yes.
Not the classic jira automation as those rights are with our admin.
But it's not basic Rovo Sudio, but Seems like Rovo Dev, so extra subscription with Atlassian.
This as the options "build" menu is not visible in mine.
So when I select automation in Rovo Studio, I get reverted to Automation in Jira.
Hi @Kartik Verma ,
It would help a lot of you post a screenshot of your automation rule flow and screenshot of the audit log.
Cheers
Rudy
This is my current config for trigger:
As far as audit logs are concerned, no automation is currently starting for this trigger.
Hi @Kartik Verma Please remove the values "create work item", "Edit work item", "Transition work item" and assign work item.
Also, once change the actor to admin instead of automation user and then test the case.
