Level 1: Seed
25 / 150 points
Next: Root
1 badge earned
The Atlassian Community can help you and your team get more value out of Atlassian products and practices.
Background:
I'm testing Jira Work Management in a free demo version, as we think about implementing it in standard license in our custom ski manufactory. When I try to create an "issue collector" for our test-project as admin, I can't find the tab "issue collector" in the settings as described here: https://support.atlassian.com/jira-cloud-administration/docs/use-the-issue-collector/ .
Thank you for your help in advance!
Hi Anton - Welcome to the Atlassian Community!
Take a look at this article.
https://support.atlassian.com/jira-cloud-administration/docs/allow-anonymous-access-to-projects/
You can also use Customer Portal for this
Try adding this to your Jira link -> /secure/admin/ViewGlobalCollectors!default.jspa
Thank you, this Customer Portal is a helpful view.
Only, as I was using a free version, I could not implement issue collectors on that page. In standard version this should work though.
