smart value for extracting certain parts of an issue and use it as label
Corinna Haberbosch
February 23, 2021
Dear All,
I have created a mail handler in JIRA Core so issues are created for incoming mails.
These mails contain words or catch phrases which are the base for the labels in the issue. I want JIRA to automatically label the issues on the base of the Description.
I have suceeded in setting up the rule for fixed terms:
When: Issue Created
Branch: For Current Issue
Description Contains {{a certain word}}
Then: Edit Issue Fields
Now I am wondering if it is also possible that JIRA recognizes a certain word in the Description (let's say "cost") and takes the 10 digits after that word and puts this number in a pre-defined "cost" label?
Thanks for your help!
Best, Corinna
Kian Stack Mumo Systems
@Corinna Haberbosch
Sure you can.  Try using the smart value configured like this:
{{issue.description.match(".*cost ([0-9]{10}).*")}}
This will grab exactly 10 digits following the text "cost ". If there are fewer than 10 digits it won't work. If you wanted to grab any number of digits, you could instead use a smart value like this:
{{issue.description.match(".*cost ([0-9].*).*")}}
My automation rule is configured as follows:
Corinna Haberbosch
February 24, 2021
Dear Kean,
thank you for the prompt reply.
It doesn't work yet, so here is my concrete use case:
The Description Text contains an ISBN which is formatted as follows:
ISBN: 978-1-5015-1655-9
There is a predefined text field "ISBN" and I want the 17 digits to be drawn into this field.
I have adjusted your smart value suggestion as follows.
Maybe you have another suggestion?
Your match function is wrong.
Try this:
{{issue.description.match(".*ISBN: ([0-9]{3}-[0-9]-[0-9]{4}-[0-9]{4}-[0-9]).*")}}
Corinna Haberbosch
February 25, 2021
Dear Kian,
ah - now I got the twist :)
I have used this in the meanwhile:
{{issue.description.match("ISBN:\s(.*)")}}
which also worked.
But thanks, that was helpful! I think I understood the rule now.
Best, Corinna
Like Srinivasa Reddy Yeruva likes this
