We have been using JIRA automation to update fields in an issues, and the updates rely on using Smart Values.
lately, we have started to hit limits in the number of Automation Requests, and because of that, our processes are getting disrupted.
We are not ready to jump to the higher levels of JIRA that provide increased automation.
I am looking for alternative solutions.
The Specific Use Case I am trying to address is:
* An issue owner enters a 1 line daily update.
* Automation will get triggered to take that 1 line update, pre-pend date / time / User Name and then add it to the top of a read-only field that has the full list of updates.
It would be great if this could be handled within the workflow post function, however, Smart Values are not supported.
Smart values are only available inside Automation actions — they were never wired into native workflow post functions (Cloud or Server/DC), so that path is a dead end regardless of plan tier. A few ways to keep this working without eating more Automation executions:
Worth checking #1 first — it's free, takes ten minutes to verify in the rule's execution log, and is a more common cause of hitting the cap than people expect.
The automation is properly scoped. I am currently investigating work flow extentions.
thanks
Optimizing your existing Jira Automation Rules would give relief for some extent in your case.
If you prefer to keep your current Jira Automation setup, you can drastically reduce execution consumption by :
Scope Rules to Single Projects: Multi-project or Global rules consume your global monthly execution quota faster. Single-project rules often have higher or separate allowances depending on your plan.
Use Workflow Transition Triggers Instead of Field-Value Changed:
A Field Value Changed trigger runs every time an issue edit event occurs, which can accidentally trigger multiple runs.
Change the trigger to Issue Transitioned (or a dedicated transition button) so the rule executes only when explicitly submitted.
I know that some of our clients lean toward buying a Marketplace app (e.g., ScriptRunner or JWME) if they want to reduce the number of automation executions, as these apps can do the same thing while there's no execution limit. 👀
Still, that's an additional cost, as you need to actually buy the app.
As you're looking for something related to workflows (which would require user to actually trigger some kind of transition)... Potentially, you could explore using Trigger agent action if you're able to use Rovo/AI. Basically, you could built an agent that would do all of those things you require and it would be triggered on workflow transition.
This would still be relatively experimental but should be fairly easy to build.
Apart from that, you could try out this as well > Build custom Forge apps in Rovo Studio - no code required! > Pretty much build your own 'app' that would handle these things, even without the need for a manual workflow trigger. 🤔
Note that all of this, related to AI, is subject to change. Meaning, potential limitations on tokens, usage, etc., will be applied, so while it might work now, you'll have to deal with it at some point.
Cheers,
Tobi
If I am not mistaken, the post-function requires a transition. Do your issues transition to another status when the automation adds the values entered by the user?
Does your automation run every time the value is added or does it run once a day? If it runs every time, maybe you could consider changing it to run daily (for example at 00:00). It should save you some automation executions.
in the case i am working on currently, the automation is based on transitions.
i have considered more of a batching of these requests, which would be possible, however, i was holding off this as a last resort.
Using the extended workflow plugin or rovo would be a more ideal solution
