How Can I Hide Parts of an Issue from Particular Groups / Users?
Deleted user
February 8, 2016
Hi there,
I realize that I am trying to use JIRA (cloud version for now) in a way, that it was not originally meant to be used, but I'll ask anyway:
I currently use Kanban to visualize our customer onboarding process. Once they are live, I would like to use the cards (card = customer) as a kind of customer database. E.g. by copying to another project, where other employees can access non-sensitive data regarding the customer.
In order to accomplish this, I would like to remove certain sections of the issue:
Must: history & activity stream
Nice to have: Gliffy diagrams, attachments, transitions
The whole idea is to automatically use some of the relevant information gathered during onboarding and provide it to other users, e.g. support employees. These employees should, however, not know about the more sensitive details of the customer.
Do you have any suggestion how I can accomplish this? Any help is greatly appreciated
Joe Pitt
February 8, 2016
You can't. You can hide issues using issue security, but if they can see the issue they can see everything on it.
Midori
February 9, 2016
You cannot set visibility on field level using built-in JIRA features. There is a some popular feature request for this, but that was reviewed and postponed by Atlassian.
This add-on is a popular work-around though, which may or may not work in your case: https://marketplace.atlassian.com/plugins/com.quisapps.jira.jfs/server/overview
Sarika Dalal
you can hide the part of issue from work flow condition and post function.there is condition for set user field on particular transition in which you give those user /group name  who will be assignee of that issue automatically it will hide transition from other users.
Deleted user
February 8, 2016
I almost thought so. Do you see a possibility on how I can (automatically, e.g. via Workflow) extract some issue fields and provide the contained information to other users somewhere else? Either in confluence or in JIRA?
Joe Pitt
February 8, 2016
The technical issue I see is how would you pass to the workflow where to put the info you want extracted? If you weren't in the cloud you might be able to use a listener to fire on the transition and pull the contents of specific fields and email them to create a new issue those people would have access to.
