Fresh Jira - EKS installation running into issues starting Jira
Lloyd Kim
November 11, 2024
That is the error I am getting, and not exactly sure how to get around it via EKS environment.  Any help appreciated.
This is a brand new installation, and not exactly sure if I am supposed to go to a page to configure the database or initialize the database.  The load balancer and the target group is showing unhealthy, so I am not able to get to the site via the ALB.  Is there something I am missing?  Thanks again for any ideas
  ___ Starting the JIRA Plugin System _________________ 2024-11-11 21:31:31,480+0000 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/jira/dbcon fig.xml 2024-11-11 21:31:31,528+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running Jira startup checks. 2024-11-11 21:31:31,528+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Jira pre-database startup checks completed successfully. 2024-11-11 21:31:31,564+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is not yet configured. Enqueuing Database Checklist Launcher on po st-database-configured-but-pre-database-activated queue 2024-11-11 21:31:31,565+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is not yet configured. Enqueuing Post database-configuration launc hers on post-database-activated queue 2024-11-11 21:31:31,576+0000 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Startup is complete. Jira is ready to serve. 2024-11-11 21:31:31,578+0000 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
Lloyd Kim
November 11, 2024
Instead of localhost on EKS cluster you need to go to the pod ip address on port 8080.  This allowed me to go and configure the database and JIRA.
SERVER
