Card Color showing for some users and not for others
Kevin Labrum
July 26, 2018
I have created a Kanban board with multiple projects. In the board settings, under Card Colors I have created the following query for a custom field that we want the card to turn red: "Hard Deadline?" = "Yes - There is a Hard Deadline"
For some reason, some users see the red bar on the left of the card on the board and for other users there is no color at all.
Earl McCutcheon
July 31, 2018
Hello Kevin,
Since this is occuring for some users but not others it sounds like a browser or network segment conflict.
Check out this Guide for steps to take to help narrow down the conflict point.
Regards,
Earl
Kevin Labrum
August 20, 2018
I don't believe this is the problem. I logged in as the user and other users and I experience the same issue they are seeing.
brian steele
December 6, 2018
@Kevin Labrum I'm running into this same issue setting up our new cloud instance. Were you ever able to work out the issue?
Kevin Labrum
December 6, 2018
Negative nothing yet.
brian steele
December 6, 2018
It seems to be associated with our custom roles. If I have a user in our custom "developer" role, then they don't get the colors. If I have them in our custom "quality" role, they can.
