Bulk Cloning Jira Issues, but need to keep same Issue Key
Theresa Gothard
January 30, 2023
Hello!  I'm maybe not going about this the correct way, so please let me know if there is a more efficient way to do this.
We currently have a team-managed project that I'd like to move over to a company managed project.  I have set up the new project and would like to clone all the issues into the new project.  However, I need to keep the Issue keys the same (the letters can be different, but the numbers need to be the same).  In my research, I have not seen a solution to this, so maybe it's not possible?
Or should I be going about this differently?
Thank you!
Theresa
Nic Brough -Adaptavist-
January 30, 2023
The only way to do this would be to create the issues in a strict order.
Imagine you've got
  • ABC-12
  • ABC-16
  • ABC-18
That you want to clone and move into a project currently having the last issue as XYZ-10.  You will need to
  • Create XYZ-11 (and delete it if you don't need it)
  • Clone ABC-12 and move the issue into XYZ
  • Create XYZ-13 (and delete it if you don't need it)
  • Create XYZ-14 (and delete it if you don't need it)
  • Create XYZ-15 (and delete it if you don't need it)
  • Clone ABC-16 and move the issue into XYZ
  • Create XYZ-17 (and delete it if you don't need it)
  • Clone ABC-18 and move the issue into XYZ
This effectively makes the target project pretty much useless.
So, I have to ask - why are you wanting to do this?
Theresa Gothard
January 31, 2023
Thanks - I need to move to the company managed project because there is functionality that I'm looking for that is not available in the team managed project.  Unfortunately, my QA team is very familiar with the specific issue keys and really need to keep them the same when we move over.
Vish Reddy {Revyz}
Hi @Theresa Gothard
We are building a solution to help you move your Team Managed projects to Company Managed projects in an easy way while keeping your KEY the same. Happy to run you through in more detail what we are building if interested.
Thank you
Vish
Theresa Gothard
February 1, 2023
Hi @Vish Reddy {Revyz} ,
Yes I would be interested to see what you've come up with.
Thanks,
Theresa
Like Vish Reddy {Revyz} likes this
Vish Reddy {Revyz}
Hi @Theresa Gothard
I could be reached out vish@revyz.io, i will share my calendar once I hear from you.
Looking forward to our meeting.
Thank you
Vish
