Community Announcements have moved! To stay up to date, please join the new Community Announcements group today. Learn more
×Hello,
I am testing the Jira Work Managament (JWM) to see if it is sufficient for my clients project needs and to investigate if we can integrate it into our workflow as well as Confluence.
At the moment, I have several projects set up in JWM and each connected to its own Slack channel. Our team needs to be able to create tasks in that channel using the /jira create command. The individual Slack channels are private and only accessible to certain team members. When executing the command, a form opens showing a dropdown menu to select the different JWM projects. Is it possible to deactivate this dropdown so that certain members do not have access to these projects?
Many thanks in advance!
Julia Viers
Hello, Good day. You could remove the create issue permission for the users on the permission scheme.
