I have been using this regex to find reference to other ticket in comments and make a related link:
[A-Z]+-\d+
it works, but it is too general and often causes errors for things that aren't really a ticket descriptor. I changed to this:
[A-Z]{2,8}\b-\d{3,6}\b
which is specific enough to catch things much more finitely.
However, when the automation runs the command to establish the link
{{comment.body.match("{{[A-Z]{2,8}\b-\d{3,6}\b}}")}}
it fails because it is seeing the commas in the regex as delimiters and generates this error:
{{comment.body.match("{{[A-Z]{2: Issue does not exist or you do not have permission to see it., 8}\b-\d{3: Issue does not exist or you do not have permission to see it., 6}\b}}")}}: Issue does not exist or you do not have permission to see it.
Any ideas on how to fix this?
Do you mean to match the literal {{ }} sequences in your input string? If so, you might need to escape them.
{{ comment.body.match("\\{\\{[A-Z]{2,8}\b-\d{3,6}\b\\}\\}") }}
Could you post a screenshot of your automation rule here? I suspect you're trying to attach the link, and search the comments in the same step.
If that's the case, I may suggest creating a Variable a few steps ahead in the rule, and then referencing that variable (if it returns something) in the Link step instead.
and here's the original that works (but is too general, but doesn't need comma's)
I tried the variable option and it seemed promising as it didn't cause a comma error, but it also doesn't seem to catch any return from the regex (even though the exact same regex is resolving as true in the IF comparison check. A log of the variable returns blank.
