Data Load issue in POWER BI CONNECTOR in JIRA
paritosh.verma@envestnet.com
November 20, 2024
We have just integrated Power BI Connector for Jira
For generating reports in Power BI using Jira Data but data load using this connector is taking a lot of time.
Kindly provide some methods to tackle this.
Anna Odrynska - Alpha Serve
November 21, 2024
Hi paritosh.verma@envestnet.com
Welcome to Atlassian community! Please, submit a support request here:
https://aserve.atlassian.net/servicedesk/customer/portal/16
Anna
November 21, 2024
Hi Anna,
I have already filed a support ticket for the same.
https://aserve.atlassian.net/servicedesk/customer/portal/16/POWERBI-5408
Marc -Devoteam-
Welcome to the community.
As this is functionality is based on a 3rd party app, I have used the app.
They process the data based on the connector you setup. Depending the amount of data and the options selected you are pulling in the connector the load could be lengthy.
So you can adjust your connector scope and settings of what data you require.
If you already have set a small scope and a small amount of data points, and its still very slow, contact the app support department.
November 21, 2024
Thank you Marc
I have raised a support ticket to check further
PREMIUM
