Azure monitor to JSM integration using Automation rule (incoming webhook)
Vijay Koneru
June 6, 2023
I created automation rule with incoming webhook to integrate Azure monitor(metric and log alerts) with Jira service management. The payload I received from Azure is not in JSON format due to which I am not able to read specific values.
Did anyone experienced similar issue while integrating azure monitor with JSM ?
