I am currently assessing the standard and premium version of Jira Service Management,
I am a bit confuse on how to determine if my automation I am planning is
counted as Automation or Global Automation or Multi Project automation.
What is the key difference and how to determine?
Thank you in advance.
Hi @Nico Ocampo ,
If you're in Automation screen, you can determine your automation scope here
Or if you're in rule detail, you can determine your automation scope here
As you can see:
Hope this helps!
Hi @Thuan_ Do Dang why is my rule only able to be set for global? I can't edit the scope.
Hi @jellyjilli ,
What is your role in your site?
Automation scope will be set 'All project' when created from Global Automation and 'Single project' when created from Project by default.
To edit Global Automation you should be Site admin.
To edit Project Automation you should be Site admin or Project admin with Option 'Allow project administrators to manage project rules.' enabled.
Hope this helps!
This is what you need to focus on relating to usage counts -
As described in this Atlassian page - https://support.atlassian.com/cloud-automation/docs/how-is-my-usage-calculated/
So, if a rule is shared by multiple projects, then it is treated the same way as a global rule - which it counts against your execution count allowed based on your subscription tier.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
Hi @Nico Ocampo ,
