I'm looking to create an automation in two separate projects in which one field in project A has an allocated resource ID # (the field would not have a set context, as the ID #s could go on and on).
Once I set the resource ID #, I would like to set up an automation to link it to another project ticket where the same field has the same allocated resource ID #.
Is this possible with automation? Can anyone give me a recommendation on where to start?
It is much appreciated!
Thank you!
Yes, this is possible. Please note that for global / multi-project spanning automation rules, there are licensing limits on how many executions you can have per month. These sources explain how that works for the different levels. I cannot tell if you are on the Cloud or Server/Data version, so I'll assume Cloud for now.
Now, how would you do implement this...
To help you get started, here are some example rules and documentation sources. If you need more help, post an image of your rule and the community will help.
Best regards,
