I've run into an issue where the {{comment.author}} and {{comment.body}} tags are not working when I attempt to use them on the Project Automation page in Jira Service Desk.
Now comment on an issue by replying to the "new request" email or by adding a comment directly using the web portal.
The notification that is sent has the comment.author shown as a random string of characters.
The comment.body will parse hyperlinks strangely and occasionally will add things like {color:grey} to the end of the comment body. The {color:grey}{color} seems to only happen when the comment is made via email from a known user. Emails from non-user requestors don't have the {color:grey} problem.
I know there is a "Customer Notification" module, but that does not grant access to customizing emails that Agents receive. I'm trying to create a custom email for agents when a comment is made and I'm noticing this strange glitch with the comment tags.
I tried removing all HTML and using just the comment tags and I had the same problems with the comment.author being a random id, {color:grey} tag after the comment.body, and hyperlinks being parsed incorrectly.
I figured out the issue with the author. You need to use {{comment.author.displayName}}
I was referencing this: https://support.atlassian.com/jira-software-cloud/docs/smart-values-general/
But then I saw the displayName property listed here: https://support.atlassian.com/jira-software-cloud/docs/what-are-smart-values/
when using comment.body, if someone adds a username picker, it shows the account ID number instead of the person's name. Do you know how to resolve it?
