Pretty Print and other power ups are not visible for public board view
Madarasz, Norbert
November 20, 2024
hi all,
can you please help how I can make the different power ups (but mainly pretty print) visible and available for a board, which I made Public?
If I am logged in with board owner user, then the Pretty Print and other power ups are visible:
but if I open the board with Public link and without login, power ups (Pretty print) is not available:
why is like that? do you know any workarounds?
thanks a lot!
Renato Fagaraz
November 25, 2024
Hi @Madarasz, Norbert !
What happening here isn't really related to the visibility on your board but rather to your membership status.
When you make a board public and access it without being a member, you can't use any of its Power-Ups. In the example you set up, you're accessing the board without a login and, therefore, aren't a member, rendering you unable to use any Power-Ups.
Hopefully that helps!
kathimonicatti
January 17, 2025
I am using a login and am a member of my board, and I still cannot locate the "Pretty Print" Power-Up.  Please help.
FREE
