When uploading data to Power BI, it only allows for a max of 100 rows. How do I get past that?
Aidan McDowell
February 24, 2026
I've created an API token and have uploaded the data through the Web option in Power BI and I get the information I need, but not all of it. It shows me a maximum of 100 rows when I need much more. How do I get by this obstacle?
Mirek
Hi @Aidan McDowell
Unfortunately on Jira Cloud there are limits how many objects can be used though API..
https://jira.atlassian.com/browse/JRACLOUD-67722
The workaround might be to modify your Web Query and use pagination on the specific request
Set maxResults=100
Increment startAt (0, 100, 200, 300, etc.)
Example:
https://your-domain.atlassian.net/rest/api/3/search?jql=project=XYZ&maxResults=100
&startAt=0 ...
then startAt=100 .. etc. until you get total..
Ajay _view26_
Hi @Aidan McDowell ,
If your dataset is relatively static, you can export issues from Jira using JQL (up to 1,000 at a time via UI export), then import the CSV into Power BI. Less elegant but works immediately.
Hope this helps!
