Hi community,
Our client would like a feature that limits the number of approvals to one per group in multi-group approval workflows. Specifically, when there are multiple users in a group, once the first person in the group approves a request, the remaining members of that group should no longer be able to approve or decline it.
Problem Statement:
The current implementation allows multiple members of the same group to approve a request. This can lead to situations like, the first member of the group approved the request, but later a second member from the same group declined it. This creates confusion and the potential for conflicting actions from users within the same group.
Proposed Solution:
Once a member from a group approves a request, other members of that same group should no longer be able to interact with the approval process for that request.
Hi Chris, welcome to the Atassian Community!
From what I understood, this functionality is already present in the Workflow approval proccess:
That way, only one user is required to approval from each group.
Hi Deivid,
Thank you for your reply.
The approval status configuration is the same as the one you shared, and two user groups were used (Group_A and Group_B).
To provide an example of the actual behavior observed:
A member of Group_A approved the request. While the ticket was waiting for approval from Group_B, a second member of Group_A declined the request via email.
What our client has suggested is the following:
Regards,
Chris
Sorry, but I’m not understanding why this configuration doesn’t meet the client’s request.
If the configuration is set up as shown, once a user from Group A approves it, no one else from that group can interact with the approval anymore (Because is set to "one user per group) — only users from Group B can.
If what you’re trying to do is dynamically change the number of users required to approve the request — for example, if two users per group are required and one user approves, reducing it to one user per group — that’s not possible to do. Could be possible using plugins but I'm not sure on that
