How to create Jira ticket by default as a 'problem' not 'incident' using create ticket API
Rachael Harris
September 1, 2021
Hi All,
We are using rest/servicedeskapi/request API to create JIRA ticket.
Now while creating the ticket by default issue creating as Incident, but we want it should create default as Problem in Jira.
It might be some configuration required while creating the ticket.
Could someone help us to fix this issue?
Regards
IncomeGenius Team
Michael Andolfatto
September 2, 2021
Hi @Rachael Harris ,
An issue's type that is created via API can be configured as per the documentation here.
If your issue is with the default issue type specifically, this can be set within your project's Issue Type Scheme.
SERVER
