Add body of incoming email as comment to Parent issue by checking the value in comment on the issue
G P N
December 16, 2025
I have a requirement. When I receive an email in the Jira Inbox from "test@mail.com" with the subject : Test successful for {ABC12345678}
body contains : test successful for {ABC12345678}
It should add the body as a comment to the parent ticket that has the {ABC12345678} value for the custom field or in the comment.
{ABC12345678} is a custom field value or this value {ABC12345678} is already added in the comment. How to fetch the issue key with this value.
Which approach is best: the Enterprise Email handler or the ScriptRunner Mail handler or we are also using JEMH?
Any guidance, documentation, or examples would be incredibly helpful. Thanks for your time and expertise!
3 votes
Sambar Khan
December 16, 2025
Jira’s default email handler is limited. It can only act when the issue key is already present in the email subject. It cannot extract a value using regex, search a custom field using JQL, and then decide which issue should receive the comment.
With ScriptRunner, this flow is supported:
Extract {ABC12345678} from the subject or body using regex
Use that value in a JQL search against the custom field
Identify the matching parent issue
Add the email content as a comment
This is a standard use case for ScriptRunner custom mail handlers. The official documentation with examples is available here and opens correctly:
Mail Handlers
That page explains how to build custom mail handlers and how to run JQL inside them, which fits your scenario exactly.
If the issue key is not present in the email, ScriptRunner is the safest and m
G P N
December 19, 2025
Thank you for the clarification.
When i try to work with ScriptRunner custom mail handlers and try to Run it. It's giving me the message even when i sent the mails to my mailbox.
"No messages with 'eml' or 'txt' extension were found in this mailbox. To prooperly test this handler, populate your mailbox with a few emails first an re-run the test.
Found 0 messages in the directory: /data/sharedhome/import/mail"
Any suggestions on this. I am using Jira Data center.
Like Susan Waldrip likes this
G P N
January 12, 2026
@Sambar Khan I have updated the question. Could you help me with this?
Thank you in advance!
2 votes
Hari Krishna
Hi @G P N ,
For this kind of requirement, ScriptRunner’s Mail Handler is the better fit.
The built-in Jira (Enterprise) email handler is really meant for simple scenarios only — things like creating a new issue from an email or adding a comment when the issue key is already in the subject. Once you go beyond that, it starts to fall short.
In your case, you need to:
read a value from the email using a pattern,
search Jira using that value in a custom field,
and then decide what to do based on the result.
That kind of logic just isn’t something the standard email handler can do. ScriptRunner is designed exactly for these situations and gives you the flexibility you need to make this work reliably.
G P N
December 19, 2025
Thank you for the suggestion and your time😊.
Ram Kumar Aravindakshan _Adaptavist_
Hi @G P N
Please clarify, are you trying to do this on Jira Server / DC or Cloud?
If it's for the former, then ScriptRunner does provide the mail handler feature. However, if it's for the latter, ScriptRunner does not provide the feature by default.
If you are trying to achieve this in Jira Cloud, you will have to look into Forge.
Thank you and Kind regards,
Ram
FREE
