HI
I am tryin to
copy project components/Fix versions to another project component/Fix versions in Data center.
I used approach CSV import but it is missing few data still,
can anyone tell any other approach by using Rest API or Script runner through.
Thank you
Hi @vasanth
For your requirement, you will need to use the REST Endpoint to get the versions from the previous project and the ScriptRunner console to copy the versions into the second project.
For the REST Endpoint, you can try something like this:-
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import groovy.json.JsonBuilder
import groovy.transform.BaseScript
import groovyx.net.http.ContentType
import groovyx.net.http.HTTPBuilder
import groovyx.net.http.Method
import javax.ws.rs.core.MultivaluedMap
import javax.ws.rs.core.Response
@BaseScript CustomEndpointDelegate delegate
convertToJson { MultivaluedMap queryParams ->
def hostUrl = "http://localhost:9091"
def userName = "admin"
def password = "q"
def projectKey = "SFFM"
def httpBuilder = new HTTPBuilder(hostUrl)
def versions = [] as List
def issueJson = httpBuilder.request(Method.GET, ContentType.JSON) { req ->
uri.path = "/rest/api/2/project/${projectKey}/versions"
headers.'Authorization' = "Basic ${"${userName}:${password}".bytes.encodeBase64()}"
response.failure = { resp, reader ->
log.warn "Failed to query JIRA API: ${reader.errorMessages}"
return
issueJson.collect { Map row ->
versions.add(row.get("name"))
return Response.ok(new JsonBuilder(versions).toPrettyString()).build()
Please note, the sample codes provided are not 100% exact to your environment. Hence, you will need to make the required modifications.
Below is a print screen of the REST Endpoint configuration:-
If you notice in the code, the versions are taken from the Scripted Field For Mail (SFFM) project.
Once your REST Endpoint is configured, you will need to invoke it using the ScriptRunner console.
Below is a sample code for your reference:-
import com.atlassian.jira.component.ComponentAccessor
import groovy.json.JsonSlurper
def projectManager = ComponentAccessor.projectManager
def versionManager = ComponentAccessor.versionManager
def baseUrl = "http://localhost:9091"
final String projectKey = "COM"
final Date startDate = null
final Date releaseDate = null
final String description = null
final Long scheduleAfterVersion = null
final boolean released = false
def project = projectManager.getProjectObjByKey(projectKey)
def hostUrl = "${baseUrl}/rest/scriptrunner/latest/custom/convertToJson"
def response = hostUrl.toURL().text
def json = new JsonSlurper().parseText(response)
def artifacts = json.collect().sort()
artifacts.each {
versionManager.createVersion(it.toString(), startDate, releaseDate, description, project.id, scheduleAfterVersion, released)
In the code above, the code is to be stored in the Communications (COM) project.
Below is a print screen of the Script Console:-
Below are some test screens:-
1) Below is the version screen for the Communication project before the script is executed.
2) Once the script is executed on the Script Console, the list of versions will be displayed in a list as shown in the image below:-
3) Now, if you go to the version page once again, you will see that the versions have been added, as shown below:-
I hope this helps to solve your question. :)
Thank you and Kind Regards,
Ram
Hi @vasanth
I'm glad to hear the solution helped. :)
Please accept the answer.
Thank you and Kind regards,
Ram
Hello @Ram Kumar Aravindakshan _Adaptavist_ , I'm trying to get this to work in Data Center. I created the REST Endpoint with the Key from the source project and ran the script with the destination project key. I've tried it with http and https. It runs and nothing happens, and the results are empty. I've tried the REST endpoint with my regular user/pass and user/api key (I am a system admin).
Is there any other setting I need to customize other than
def hostUrl
def userName
def password
def projectKey
def baseUrl
final String projectkey
Any help would be appreciated and I can also open a ticket with Adaptavist if that would be easier.
Using the Console of ScriptRunner you can use the below code to clone the versions of the Master project to sub-projects.
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.version.Version
def projectManager = ComponentAccessor.getProjectManager()
def projectSource = projectManager.getProjectObjByKey("SourceProjectKey") // Source project name here
def projectDestination1 = projectManager.getProjectObjByKey("DestinationProjectKey") // Destination project name here
def versionManager = ComponentAccessor.getVersionManager()
List<Project> projectList = new ArrayList<>();
projectList.add(projectSource)
Collection<Version> versionList = versionManager.getAllVersionsForProjects(projectList, false)
for (version in versionList) {
def versionname = version.getName()
if (versionname.length() >= 3) {
log.debug("Now adding version " + version + " to " + projectDestination1.name)
versionManager.createVersion(version.name, version.startDate, version.releaseDate, version.description, projectDestination1.id,null, version.released)
else {
//do nothing
I've modified the code to consider a few more scenarios.
//Created - 6th June 2022
//Last Modified - 28th May 2024, 03:48 PM
//Authors - Ahmed Salem Iskander (from community post)
//Modifiers - Rinaldi Michael
//References -
//https://community.atlassian.com/t5/Jira-questions/Jira-copy-project-components-Fix-versions-to-another-project/qaq-p/1749456
import java.lang.String
import com.onresolve.scriptrunner.parameters.annotation.*
import java.util.ArrayList
//Get Input
@ShortTextInput(description = 'Type in the Project Key from where you would like to copy all Releases/Versions', label = 'Enter Source Project Key')
String sourceProject
@ShortTextInput(description = 'Type in the Project Key where you would like to copy all Releases/Versions into', label = 'Enter Target Project Key')
String targetProject
//Declare variables
def projectSource = projectManager.getProjectObjByKey(sourceProject) // Source project
def projectDestination1 = projectManager.getProjectObjByKey(targetProject) // Destination project
//Get source project object
//Get target project object
List<Project> projectList2 = new ArrayList<>();
projectList2.add(projectDestination1)
Collection<Version> versionList2 = versionManager.getAllVersionsForProjects(projectList2, false)
//Set output variable
String printtext = ""
//Recreate all versions in the new project
printtext+="<b>${versionList.size()}</b> Versions will now be copied from <b>${projectSource.getName()}"
printtext+=" (Key: ${projectSource.getKey()})(ID: ${projectSource.id})</b> to <b>${projectDestination1.getName()}"
printtext+=" (Key: ${projectDestination1.getKey()})(ID: ${projectDestination1.id})</b>"
//Loop through all values that should be copied
for(int v=0;v<versionList.size();v++)
def version = versionList[v] //Source project version
def versionname = version.getName() //Source project version name
boolean alreadyExists = false
//Verify if a Fix version with the below details already exists
for(int fv=0;fv<versionList2.size();fv++)
if(version.name == versionList2[fv].name)
def existingPosition = fv
//This part is only needed if every detail of the version should be compared
if(versionList2[v].name==versionList[existingPosition].name
&& versionList2[v].startDate==versionList[existingPosition].startDate
&& versionList2[v].releaseDate==versionList[existingPosition].releaseDate
&& versionList2[v].description==versionList[existingPosition].description
&& versionList2[v].released==versionList[existingPosition].released)
printtext+="<br><br>${v+1}. Fix Version/Release with the below details <b>already exist</b> in the destination project<br>"
printtext+="<b>Name</b>: ${versionList2[fv].name}<br>"
printtext+="<b>Start Date</b>: ${versionList2[fv].startDate}<br>"
printtext+="<b>Release Date</b>: ${versionList2[fv].releaseDate}<br>"
printtext+="<b>Description</b>: ${versionList2[fv].description}<br>"
printtext+="<b>Destination Project ID</b>: ${projectDestination1.id}<br>"
printtext+="<b>Is Released?</b>: ${versionList2[fv].released}"
alreadyExists=true
break;
if(alreadyExists)
continue;
//Create the copy versions
printtext+="<br><br>${v+1}. Version created with details:<br>"
printtext+="<b>Name</b>: ${version.name}<br>"
printtext+="<b>Start Date</b>: ${version.startDate}<br>"
printtext+="<b>Release Date</b>: ${version.releaseDate}<br>"
printtext+="<b>Description</b>: ${version.description}<br>"
printtext+="<b>Is Released?</b>: ${version.released}"
else
printtext+="<br>${v+1}. Version not found/added"
return printtext
