Problem in Automation for JIRA Edit Issue
GG
I want update single select field values based on other single select value. I use this sample code, but I received error "Error while parsing additional fields.Not valid JSON ":
Scenario is : I have tow single select list fields. When I select one option in firs field I want remove some options in second field.
  "expand": "projects",
  "projects": [
      "expand": "issuetypes",
      "self": "https://jira.atlassian.com/rest/api/2/project/10240",
      "id": "10240",
      "key": "JRA",
      "name": "Jira (including Jira Core)",
      "avatarUrls": {
        "48x48": "https://jira.atlassian.com/secure/projectavatar?pid=10240&avatarId=17294",
        "24x24": "https://jira.atlassian.com/secure/projectavatar?size=small&pid=10240&avatarId=17294",
        "16x16": "https://jira.atlassian.com/secure/projectavatar?size=xsmall&pid=10240&avatarId=17294",
        "32x32": "https://jira.atlassian.com/secure/projectavatar?size=medium&pid=10240&avatarId=17294"
      "issuetypes": [
          "self": "https://jira.atlassian.com/rest/api/2/issuetype/10000",
          "id": "10000",
          "description": "",
          "iconUrl": "https://jira.atlassian.com/secure/viewavatar?size=xsmall&avatarId=51505&avatarType=issuetype",
          "name": "Suggestion",
          "subtask": false,
          "expand": "fields",
          "fields": {
            "summary": {
              "required": true,
              "schema": {
                "type": "string",
                "system": "summary"
              "name": "Summary",
              "hasDefaultValue": false,
              "operations": [
                "set"
            // other fields removed for brevity...
            "components": {
              "required": false,
              "schema": {
                "type": "array",
                "items": "component",
                "system": "components"
              "name": "Component/s",
              "operations": [
                "add",
                "set",
                "remove"
              "allowedValues": [
                  "self": "https://jira.atlassian.com/rest/api/2/component/36920",
                  "id": "36920",
                  "name": "System Administration - Support Tools"
                  "self": "https://jira.atlassian.com/rest/api/2/component/43995",
                  "id": "43995",
                  "name": "User Management - Delete User"
GG
Thank you for your reply.
Is there any commend to remove options from single select list?
JP _AC Bielefeld Leader_
February 15, 2020
don't know. I would ask the app devs.
Best
JP
GG
Thanks
February 15, 2020
HI,
check, if the forward slash in
Component/s
must be escaped...
Best
JP
