Custom background color not applying for help center
Administrateur Hawaii
December 17, 2019
Hello,
I'm trying to change the default background color for the help center's banner. After choosing the color and applying changes, nothing happens even 5 -10 -50 mn later.
Do you know if it's a bug or how can I resolve this ?
Thx !
Ajay _view26_
@Administrateur Hawaii
Yup , there is a problem with the usability . You need to explicitly choose the color and apply for the banner color to get reflected. Hope it helps
Refer the attached image
Kyle Parker
March 8, 2021
No matter what I try, it doesn't work.
Like 波田野創 likes this
波田野創
August 31, 2023
I have same problem...
Daniel Sidler
I found out that, to actually choose, I had to click Choose after choosing the color. A UX masterpiece indeed <g>.
