Is there a way to connect Jira Goals with Jira PRD Ideas?
Pierfrancesco Di Ruzza
May 30, 2025
Hi all! I'm using Jira Goal to track my team/product progress.
Is there a way to connect a Goal to a specific "Idea" in Jira Product Discovery?
Is this a premium feature?
2 votes
Walter Buggenhout
Hi @Pierfrancesco Di Ruzza and welcome to the Community!
This is a standard feature, even in the standard plan of JPD. You can use the Goals field to connect ideas to goals:
Just make sure that you enable the projects and goals integration in your project from Project settings > Features > Goals & Projects
Hope this helps!
June 3, 2025
Hi Walter, thank you for reaching out.
However, I cannot see this from my "Project Setting".
I can only allow the Atlas integration, not the Goals.
