Rule that creates issue, but if issue exists with same summary then just change issuetype of
Harold Pinther
March 13, 2025
Currently, a meeting ticket is generated when the component is set in the epic. If the component is changed again, another meeting ticket is created with a new ticket type. I want to prevent this new ticket creation and would then simply change the ticket type of the existing meeting ticket along with the change to the component. Therefore, it is worth checking whether the automation can prevent further ticket creation when the component is changed.
I have no glule how to handle this. Unless the doubles the rule is working fine.
Thanks in advance
2 votes
Trudy P Claspill
Hello @Harold Pinther
What is the Summary that you use when you create the Task (vs. the Story)?
Do you use any other values in the Components field? Do you set the Components field to have multiple values?
I'm trying to work out a solution, but I need the above information to complete it.
Harold Pinther
March 13, 2025
Hi Trudy, thanks for jumpin in.
The summary is Project Meetings - {{issue.key}} - {{issue.summary}}
There are only these 2 Components or none.
Harold
Trudy P Claspill
Would you anticipate intentionally having more than one child issue that has "Project Meetings" in the Summary. Or is the intention that you want to only ever have one of those for a given Epic?
Do Task and Story issue types use the same workflow and the same fields (required and optional)?
Trudy P Claspill
Did you find a solution for your problem, or do you still need assistance?
Harold Pinther
May 7, 2025
Hey Trudy, im really sorry for responding that late. The colleague stopped the request, so no need to put more work on it.
Thank you vermy much.
