Still Using Jira Automation to Tell Teams Their Work Is Unblocked?
One automation pattern appears in almost every medium to large Jira instance we review.
It usually looks something like this:
When a blocking issue is completed, check whether the dependent issue has any remaining blockers. If not, notify the assignee that work can begin.
Simple.
Useful.
And surprisingly expensive at scale.
Every time a blocking issue transitions, Jira Automation needs to:
  • Trigger on the workflow event
  • Find linked issues
  • Evaluate issue link relationships
  • Check whether any blockers still exist
  • Decide whether the issue is now unblocked
  • Add a comment, notify users, or update fields
For organizations processing multiple of issue transitions each month, this pattern quietly consumes a significant number of Jira Automation executions.
Those executions could instead power customer onboarding, approvals, release governance, integrations, or other business-critical workflows.
The Challenge Isn't Writing the Rule
Creating the rule takes only a few minutes.
Keeping it running for years is the real cost.
Solution Partners; always see, customers repeatedly face the same challenges:
  • Automation executions consumed by dependency notifications
  • Nearly identical rules copied across multiple projects
  • Rules needing updates whenever workflows evolve
  • Time spent troubleshooting edge cases around linked issues
  • Governance overhead as automation libraries continue to grow
None of these activities deliver business value.
They're simply the cost of maintaining dependency notifications.
A Purpose-Built Alternative
This is exactly why we built Unblocked: Blocker Resolved Notifications for Jira
Instead of implementing and maintaining Jira Automation rules, Unblocked focuses on a single job:
When the final blocker of an issue is completed, automatically notify the team that the issue is now unblocked.
That's it.
No complex rule builder.
No branching conditions.
No JQL maintenance.
No duplicated automation across projects.
The app continuously evaluates whether the completed issue was the last remaining blocker. If it was, it automatically adds a comment to the dependent issue, letting the assignee know they can start work.
For many customers, this replaces an entire class of Jira Automation rules dedicated to dependency notifications.
Why This Can Be a Better Fit Than Jira Automation
Jira Automation Unblocked
Every qualifying transition consumes Automation executions No Automation executions are consumed
Rule logic must be designed, tested, and maintained Purpose-built behaviour works out of the box
Similar rules are often recreated across projects One consistent implementation
Workflow changes may require rule updates No automation rules to maintain
Uses Automation capacity that could support business workflows Preserves Automation capacity for higher-value use cases
Automation remains the right choice for approvals, integrations, provisioning, notifications, and business processes.
But notifying teams that their work is finally unblocked is a very specific operational need. A dedicated solution can handle that responsibility while allowing Jira Automation to focus on workflows that truly require automation.
Why This Matters to Solution Partners
Every automation rule removed is one less asset to maintain.
For Solution Partners managing multiple customer environments, that translates into:
  • Lower Jira administration effort
  • Fewer automation rules to audit and troubleshoot
  • Reduced consumption of Jira Automation executions
  • Simpler governance across projects
  • More Automation capacity available for customer-specific business processes
It's a small optimisation on paper, but across large Jira instances it can remove many of unnecessary automation executions over time while making dependency notifications completely maintenance-free.
1 comment
MeghnaP_LogicLemur Labs
Atlassian Partner
July 19, 2026
Curious how everyone is solving this today.
Are customers generally using:
• Jira Automation?
• ScriptRunner?
• JMWE?
• Forge/Connect apps?
• Something completely custom?
It would be interesting to understand which approach has become the de facto standard.
