Some teams that already have projects running and would like to try using Portfolio have a problem with the Portfolio mechanic - that you have to create a plan from a "clean slate" - even when you import all issues you work with from JIRA to Portfolio.
By this, I mean that all the issues that are already assigned to people would all be re-planned for different people, for different times etc. Some people would get their work taken right from their tables, mid-work. PMs that are in this situation many times ask about importing assignees and I have to tell them that they just can't.
I imagine their perspective as that they would want the issues people are already working on at the start of the plan. Maybe this could be done by temporarily adding these issues into epics with top priority, but that seems a bit short-sighted.
Is this the way Portfolio is supposed to work? Is there any workaround except for starting from a "clean slate"?
Thanks for all replies!
Hey @Martin Suntinger,
thanks a lot for the answer, I'll explore the Live plans. If I have any questions, I'll just reply here.
Best regards,
KB
