Add multiple releases of a same project into a cross-project release in Portfolio
nph
I need to create a cross project release which shall include several releases coming from the same project.
It seems that by default there can be only one release per project: as soon as I have added a release from a project, this project is colored in gray and is not longer for selection when I want to add another release into the cross-project release.
Can you someone help please?
Thanks
Nghia
8 comments
Comment
Log in or Sign up to comment
Earl McCutcheon
January 2, 2020
Hello @nph ,
The Logic behind the restriction is that a release is a compartmentalized piece of each project, and if you have the ability to combine issues from multiple release within the same project at the same time they should already be lumped together into a single release, and not be separated into alternate sections, the Releases are intended to be Sequentially released mutually exclusive chunks of data.
This is noted in the Cross Project Release documentation in the section "How to add an existing release to a cross-project release" at point "4" stating:
4. Select the release you want to add. Keep in mind that you can only have one release from a project in the cross-project release.
Regards,
Earl
Like # people like this
Neil Hunt
I have read this logic, but I disagree with it. We have many components (essentially microservices) that are maintained in a single Jira project (essentially a team). Each of those components have their own versions and we track those using Jira Releases individually. For example, I have
Component A
Component B
I may have the following Releases:
Component A-1.0
Component A-1.1
Component B-3.1
Component B-3.2
Component A-1.2
And I oftentimes want to group one or more of them into a single overall release which I want to use Jira Advanced Roadmaps to track. With the current limitation of only allowing a single release from a project, there is no way to display this in Advanced Roadmaps. I would ask you to please consider adding this feature.
Also, we typically have many components (20+ per Jira project) each with their own versions. To distribute each of those into their own Jira project would be impractical.
Westlee Latta
September 16, 2021
Agreed - Atlassian should allow per-component releases from within the same project. Otherwise why do we have components at all if we're required to have a unique project per release?
tbertin tbertin
February 28, 2024
Hey!
Some years later, and it seems either no one though this would be necessary anymore, or people in need of this feature found another way to achieve what they wanted.
I for one agree with @nph , @Neil Hunt and @Westlee Latta and would very much like to use cross-project releases with several versions included from the same sub-project (owning differents components with each their own specific versions).
It seems the "component" control in Jira is somewhat limited, in a sense that components versions cannot be specified (only project ones) etc... This is not really a problem, but that highlights the limitations in component management inside a single project. For example, having only project-level releases forces users to define versions either comprised of several components (and this becomes difficult to track, as it can only be done by using and reading back the version description), or by creating specific versions for each component inside the project (which is at least better, because a Jira ticket can be assigned several versions in a project, as is possible for a real bug/task/US/whatever).
So, having multiple versions in a project to define one for each component is the best way to handle component versions now, but we currently don't have the possibility to link them all through a cross-project release, which would define a larger release step (for example: defining an end-of-increment or end-of-sprint release comprised of several component upgrades).
I don't know how this limitation is handled internally, but wouldn't its removal have little to no impact on the rest of the product?
@Earl McCutcheon could someone on the Jira team at least consider it?
ZR
July 22, 2022
This is a must have. Jira has components, we can create multiple versions, recommendations for component versioning suggest using component-x.y.z, yet we cannot combine those versions using cross-project releases!
Grassmann, Oliver (O.)
August 3, 2022
So any statement by Atlassian people here?
Allowing this is crucial to successfully plan bigger projects!
Please think about it and please give some feedback, guys!
Thanks in advance & bests,
Oliver.
Shane Giroux
Atlassian is choosing again to let the tool tell teams how to work rather than letting the teams tell the tool how they work. In some cases - single assignee on an issue/work item - I can understand (even if there are valid reasons to disagree for some teams).
In others such as this case, it's a restriction that is unwelcome. Planning out a quarterly cross-project release might involve multiple releases from a single project.
Granted this is setup to get around the lack of the larger program management which I understand Program Boards are meant to handle though they have their own limitations currently (only two quarters out being a big one so you can't plan a year roadmap)
There is always the chance I - we - are incorrect in how we want to use cross-project releases but I'd need to be convinced the limitation is important to impose and more valuable to have than to not have the restriction.
Like jeroen.wilmes likes this
jeroen.wilmes
May 12, 2025
Hello Atlassian?
What is going on with this BUG in Jira Premium Plan.  the whole Release module in Plan is completely worthless, as I can only select one release per project.
Your explanation why it is by purpose limited to one release per project is completely against all documentation and instructions that are published by Atlassian.
We are paying a premium fee and don't get premium value, even not standard value.
jeroen.wilmes
December 18, 2025
The bug I raised was analysed, and it was concluded that Atlassian wanted to make a change with priority and it was added to the list of H1 2026. I have asked an update. As soon as there is good news I will share here as well.
Like kenden likes this
Shane Giroux
Do you have a link to the bug where we could also watch it/vote for it?
Thomas Vial
September 30, 2025
Same issue here, a mobile team release ios and android in different version but for same cross-project release. Can't manage it today... And no I won't create a separate project...
Why is there a limit to only 1 release per project? As stated by other before me this is a non sense.
Thank you.
jeroen.wilmes
October 1, 2025
I raised a bug for this;  please support it by doing the same. Atlassian is deaf for users.
It is only possible to select one release from a project in cross project releases in Jira Plans.
referring back to this page.
Shane Giroux
Where is the bug you raised?
kenden
December 17, 2025
One more request for this.
It's difficult for us to manage releases without a fix/improvement.
