Showing results forĀ
Search instead forĀ
Did you mean:Ā
Automation to create JPD Idea 'from' Jira issue and links as delivery project?
Glenn A
I know this is 'backwards' from the typical path, but what I want to do is create a JPD idea from a Jira issue. I have the automation working that creates the JPD idea via manually triggering on the Jira issue, but where I am running into 'fun' is on doing the delivery linkage. The standard automation path (set linked filed in the action) doesn't establish a delivery relationship. Using the API to see a JPD issue structure reveals it's more than just setting the ID of the delivery ticket.
I'll settle for a 2-step flow, where I create the base JPD issue then take that within JPD and update it to be correct (e.g.,  add a linked issue in the 1st pass on triggering from the Jira issue, then I take those values and update within JPD).
Is this even possible to do via automation?
Thanks
5 votes
Nick Haller
November 22, 2024
Hi @Glenn A ,
This should still be possible with an automation like this one below:
WHEN: Manual trigger
IF: (option) Issue type = Epic
THEN: Clone to JPD project (as idea), and link the two through:
  • is implemented by = Trigger issue
^ This link-type is the connect between ideas and deliveries, so the Jira issue will then appear in the JPD idea's delivery tab after!
Glenn A
@Nick Haller
BRILLIANT! That did the trick, thank you!
Like • # people like this
