Automation to create issue after 30 days when issue is resolved.
Jenna Clegg
October 10, 2024
Hi everyone,
I need help formulating an automation on JWM. I want to create an automation that creates a linked issue 30 days after the trigger issue has been transitioned to status "X" and a specific field selection is present.
Thank you!
2 votes
John Funk
Community Leader
Community Leader
Community Leaders are connectors, ambassadors, and mentors. On the online community, they serve as thought leaders, product experts, and moderators.
October 10, 2024
Hi Jenna  Welcome to the Atlassian Community!
You will create a Scheduled trigger that runs daily at the timing of your choosing.
Then add a JQL to the Schedule for:
project = ABC and status = "In Progress" and status changed to "In Progress" On startOfDay(-30) and "Specific Field" is not empty
Change out the project and the Specific Field names.
Then add an action for Create issue. Put in all of the fields and information you want and choose the Linked Issues field. For that field, choose the link type and then use Trigger Issue for the other value.
Jenna Clegg
October 22, 2024
Hi John!
Thank you for your help with this. We created a rule using your scheduled trigger but did have to make a few minor changes so that it worked. The rule we input is as follows:
project = UR and status="approved" and status changed to "approved" On startOfDay(-30) AND "sca status[dropdown]" = "Pending Negotiations "
We've let it run for the last couple of days but nothing has worked. I ran an advanced search and found that there were issues that this should have worked on. The advance search I ran was:
project = UR
AND type IN (Concurrent, Pre-Cert)
AND status = Approved
AND statuscategorychangeddate >= "2024-09-16"
AND statuscategorychangeddate <= "2024-09-20"
ORDER BY created DESC
Do you have any insight as to where we can adjust to ensure the trigger works?
Thank you again for your help!
Like John Funk likes this
Bill Sheboy
October 22, 2024
Hi @Jenna Clegg
In your rule's scheduled trigger, below the JQL, is this option selected:
Only include issues that have changed since the last time this rule executed
If so, is that what you want?  If not, disable the option and re-test by trying to run your rule manually under the ... menu with "Run Rule".
John Funk
Community Leader
Community Leader
October 22, 2024
What @Bill Sheboy  said  :-)
