Hi
The requirement is simple, if epic has a label then that label is also should be added to child issues.
I have other automation too
Whenever epic label is updated copy the label values to child issues .
And whenever new issue is created and issue type is not epic then copy the labels of epic to child issues.
But our customer need one more automation to schedule daily to perform same action if any issues which may have missed from above two automations.
For that
Trigger : i am using Scheduled
JQL : issuetype = epic AND labels in (a,b,c,d,e)
Branch
Story( or Other Work Items in Epic)
Using smart values conditions
Tried {{triggerIssue.labels.toString}} contains a etc...
failed
Tried {{issue.parent.labels.toString}} contains a etc..
failed
Tried {{branch.parent.labels.toString}}contains a etc..
Failed
Help me with smart value to check epic label in branch , the above all checking child issue labels hence it is failing.
Action :
add label a etc.
This is how my whole automation.
Thank you!
Sagar
