Hi everyone,
We’re working on an application development project that includes several layers of work breakdown: phases, project segments, features, epics, stories, tasks, base-level items, and subtasks.
Since we’re on Jira Premium but cannot add a separate Atlassian site, we’re limited to the standard work item hierarchy:
Initiative → Epic → Base Level Item → Sub-task
We’re trying to map our internal model to this hierarchy as cleanly as possible, and we’d appreciate guidance on best practices.
✔️ Our current thinking
Project Phase → Initiative
We believe Initiatives best represent high-level phases and will support governance and top-level reporting.
Project Segment → ?
We need something that represents a major slice of the application — bigger than an Epic but smaller/more specific than an Initiative. We’re considering mapping Project Segment to Component, since segments seem to align with parts of the application rather than timeline-based deliverables.
Feature → Epic
Stories, tasks, subtasks → Base-level work or smaller
❓ Questions for the community
Is mapping “Project Segment” to Components a recommended approach?
Or would we be better off creating a custom field for this type of categorization?
Can Components or custom fields support useful reporting (e.g., progress % or roll-up reporting)?
Do Components align well with iterative/incremental delivery, where a segment represents an area of the application rather than a time-bound Initiative or Epic?
Is our overall mapping (Phase → Initiative, Segment → Component) aligned with Atlassian best practices?
Or are we missing a better approach within the limitations of the standard hierarchy?
📌 Context
Epics feel too small for our “segment” concept.
Initiatives feel too large/cross-cutting.
We want to avoid misusing Epic/Initiative just to fit the hierarchy.
We cannot modify or extend the work item hierarchy.
Any advice, examples, or experience with similar setups would be greatly appreciated!
Thanks in advance!
