I am setting issue entity property to jira.issue.editable = false but it is still editable. Not sure what I am missing here.
Although automation is successful.
Hi Meer!
jira.issue.editable is a workflow property.
So could you clarify if you're setting the workflow property through automation?
Hi Yaman,
I was trying to set the property using automation. If this is not possible, is there any other way to set property.
Actually I am trying to make an issue read only for some users based on some triggers.
I saw one more option mentioned below, but I am not sure how to use it.
You use them on the status when editing a workflow:
https://confluence.atlassian.com/jirakb/disabling-edits-in-closed-issues-for-jira-tickets-1333332968.html
