Hello everyone,
the project I am working on contains couple hundred tests, that have test type: Generic.
I would like to enable Project Test Type settings, so I can add a test, that is generic by default.
What will happen with existing tests, and test definition within them, when I enable Project Test Type Settings?
I am being given such warning:
"All Test issues will be updated with new Test types copied from global Test Type configuration"
I am concerned, that when I enable this feature, all of my test definitions within couple hundred test will dissapear.
My concern is based on the way changing of test type works, which is:
- If test type is changed, test definition is erased.
Thank you for your answers.
