How can Jira project administrators link their project with Slack and the different parameters?
Hi Kojo.
Depending on what you want to do, you may have different ways to achieve that.
The simplest may be with automation. I know that you can create a Slack integration via the action module "Send slack message".
Does it help you ?
Thank you Flavien,
I do not really know how to create a Slack integration via the action module "Send slack message"
Can you help?
Also, can you share any articles on that?
Any feedback on this?
https://confluence.atlassian.com/automation070/how-to-use-slack-messages-with-automation-for-jira-1014664546.html
This tutorial is for DC and Server but some information (smart values) can be used in the same way.
Thank you.
