When Issue Is Mentioned in {{issue.description.body}} add as Linked Issue = Related
Vincent Lucero
Context
I'd like to improve visibility across related issues by automatically associating them with one another when referenced in either comments OR description body.
Acceptance Criteria
Example solution in bottom image for solving this when {{comment.body}} contains regex as provided by Jira Cloud default template, but when I attempt to update this, JIRA restricts me to only link issues based on "Trigger Issue" or "Most recently created issue"
Bill Sheboy
May 19, 2022
Hi @Vincent Lucero
To use the Link Issues action to a smart value expression, type (or paste) the expression in the field and it will appear below the field.  When finished typing/pasting, select the value below the field and it will be used.
This works for many of the actions which have a drop-down list of options for a target issue.
When you expect more than one issue to link, instead use the branching technique that Mark describes.
Mark Segall
Hi @Vincent Lucero - You could do something like this:
  • Create a variable to capture the key referenced in the description
  • Branch by JQL
    • key = {{yourvariable}}
    • Link to trigger issue
Vincent Lucero
@Mark Segall do you have an example of how to define variables in JIRA automation for a use case like this?
Mark Segall
Hi @Vincent Lucero - Taking a step back on this one.  I think @Bill Sheboy has the correct answer for this.  You should be able to set a smart value in your link.  What does the audit log show for your rule?
Vincent Lucero
I never implemented this rule since it wouldn’t allow me to select anything other the “trigger issue” or “last created”
I don’t know how to dynamically pass the value representing the Regex response of the mentioned ticket that triggered the automation in the first place.
Goal is to associate mentioned tickets in comments.
Vincent Lucero
@Mark Segall @Bill Sheboy any ideas on how I could proceed? 🙏
Bill Sheboy
August 31, 2022
Hi, Vincent.  Did you see this part of my response, describing how to use smart values for links?
Vincent Lucero
@Bill Sheboy Yes, the issue is that "Link Issues" as a new action does not accept smart values for me. I only can choose Trigger issue and Most recently created issue from the drop down.
Is there something I need to do to activate "Smart Values" as an option in this action?
Note that smart values are mentioned in the text below the dropdown AND shown in the built in "Link issue based on comment.body", so I believe you it is possible... But somehow disabled?
See screenshots:
Vincent Lucero
Figured it out... If anyone else encounters this see:
https://community.atlassian.com/t5/Marketplace-Apps-Integrations/How-to-use-smart-value-in-issue-link/qaq-p/1476480
In short, poor UI and you can just begin typing while dropdown is selected.
