I want to save the contents of a multi-issue picker field to another multi-issue picker field since the original field is used as a trigger. It appears that multi-issue fields are not supported in the "Choose Fields to be Set" dropdown. Also, another challenge is if I use the Additional Fields box, there is a comment that says the field must be present on the screen. My secondary, "save" field is not on any screens. Any ideas?
Please note, I am using Jira Data Center, not Jira Cloud.
