Need to create a project using Automation
sankalp_khare
Hello Team,
We need to create an automation rule where we can a project by selecting the blank project or from the template we can create the project on that
It should have all the request types forms etc
so that it is easy and convienient.
4 votes
Samuel Gatica _ServiceRocket_
November 24, 2025
sankalp_khare
Thanks Samuel,
As we are creating the project based on the shared settings
we need to copy all this things  and all the request types etc
But in summary menu - work types, priorites, workflows screens fields should be copied and automatically edited with the name of project which is getting created using automation.
Marc -Devoteam-
Hi @sankalp_khare
Request Types can't be copied.
You are creating a project based on shared settings, so it will use the screen used from the copied project, these can't be re-name automatically.
Also why should you as the projects are identical, making changes on the shared schemes will make the changes on both projects.
Like Steffen Opel _Utoolity_ likes this
