Define field configuration for company-managed spaces with schemes
10 min
Advanced
- Create a field configuration
- Create a field configuration scheme
- Associate a field configuration scheme with spaces
Field configurations define the appearance and behavior of fields. Every field configuration lists all fields in your Jira site. Jira admins use field configurations to configure several settings:
- The description, or help text, that appears under the field when users create or edit a work item
- Whether the field is hidden or visible
- Whether the field is required or optional
- Which renderer to use, wiki or default text, for text fields
When you create a space, all of the work types for that space use the Default Field Configuration. You shouldn’t modify it unless you want a configuration to apply to all new spaces.
👉 For example: You want the Description field to always be visible, required, and presented with the wiki renderer.
To create a field configuration:
- In the upper-right corner of Jira, select Settings (represented by a gear icon).
- Under Jira admin settings, select Work items.
- In the sidebar, under Fields, select Field configurations.
- Select Add field configuration.
- Enter a clear name and detailed description.
- Select Add.
- For each field, you may have several configuration options:
- Select Edit to edit the field’s description.
- Select Hide to hide the field. Select Show to show the field. You’ll only see one of these options as they are opposites.
- Select Required to require that field. Select Optional to make the field optional. You’ll only see one of these options as they are opposites.
- Select Screens to configure which screens the field appears on.
- Select Renderer to determine how to present the value of a field.
Different fields have different configuration options. For example, some system fields are always shown, so you can’t hide them.
You can use separate field configurations for each work type in a company-managed space. Jira admins define which work types use which field configurations in field configuration schemes.
👉 For example: You want to require the Environment field on the Bug work type, but you want to hide the Environment field from the Story work type.
To create a field configuration scheme:
- In the sidebar, under Fields, select Field configuration schemes.
- Select Add field configuration scheme.
- Select Add.
- Select Associate a work type with a field configuration.
- Select a work type and a field configuration.
- Select Add.
- To change the default field configuration, which applies to any unmapped work types, next to the default, select Edit.
- Select a field configuration.
- Select Update.
👇 Watch this video to learn how to create a field configuration scheme.
Associate a field configuration scheme with a space
To apply the field configuration scheme, you need to associate it with one or multiple company-managed spaces. Only Jira admins can associate schemes with spaces.
When you first create a company-managed space, it will use the default field configuration scheme for that space. You can change which scheme a space uses after you create the space.
To associate a field configuration scheme with a space:
- Open the space in Jira.
- In the sidebar, select Space settings.
- In the space settings sidebar, select Fields.
- In the upper-right, select Actions, then Use a different scheme.
- Choose your scheme, then select Associate.
Let’s explore an example!
Rory, a Jira admin, has a request from the space admin of the DEV space. The space admin says that her team needs two different due date fields: one for bugs and one for tasks.
Rory asks about her specific needs and discovers that the DEV space needs different behavior for the Due Date field, but not two separate fields.
To meet this requirement:
- Create two new field configurations or modify existing ones. If Rory modifies existing field configurations, his changes will apply to all spaces associated with that field configuration.
- Configure the “DEV Bug field configuration.” Make the Due Date field required and add a description of Requested fix date.
- Configure the “DEV Task field configuration.” Make the Due Date field optional and add a description of Completion target date.
- Create a new field configuration scheme or modify an existing one. If Rory modifies existing field configuration schemes, his changes will apply to all associated spaces.
- Map the DEV Bug field configuration to the Bug work type.
- Map the DEV Task field configuration to the Task work type.
- If the DEV space uses a different field configuration scheme, associate the correct field configuration scheme with the space.
How was this lesson?
next lesson
Define work types for company-managed projects with schemes
- Configure work type hierarchy
- Create work types
- Configure a work type scheme
- Let’s explore an example
