Create Jira automation flows for developer productivity
5 min
Advanced
  • Explore use cases to meet complex business requirements
  • Create an automation flow that auto-assigns work based on capacity
  • Create an automation flow that creates sub-tasks
  • Create and use a flow with an incoming webhook trigger
Auto-assign work based on your team’s capacity
Your team may have a backlog of tasks that anyone can work on. Rather than manually select work, you can use automation to automatically distribute work to your team.
There is a template flow that automatically distributes work. You can use this flow to start and modify it to your needs.
👇Click the boxes below to explore configuring this automation flow.
Automatically create sub-tasks
You may have a task with a set of sub-tasks that your team uses frequently. To save developers time and effort, you can automatically create and populate those sub-tasks.
Automatically trigger actions in Jira from integrations
You can use automation to trigger actions in your Jira space using events and information from other apps, like messaging applications, databases, calendars, and repositories. You’ll do this using webhooks, a simple data integration between two applications.
This automation requires you to get a webhook from an external application. Those apps should have documentation to help you.
How was this lesson?
FAQsForums guidelines
