15 min
Advanced
  • Use smart values in flows
  • Use branch flows to perform multiple actions
Let's explore an example
"parent" is not EMPTY
How was this lesson?
next lesson
Best practices for managing automation flows
  • Manage automation flows
  • Troubleshoot automation flows
Go to next lesson
FAQsForums guidelines
