15 min
Intermediate
  • Use smart values in flows
  • Use branch flows to perform multiple actions
Let's explore an example
"parent" is not EMPTY
How was this lesson?
next lesson
What is automation?
  • Build flows that automate manual tasks
  • Who can use automation?
Go to next lesson
FAQsForums guidelines
