Create complex automation rules with smart values and branches
15 min
Advanced
- Use smart values in rules
- Use branch rules to perform multiple actions
Reference a smart value in an automation rule
👉 For example: You’re creating an automation rule to add a comment to a Confluence page whenever it is updated. You want the comment to include the date and time of the update. Since this rule will run frequently and on various days in the future, you can't specify a fixed date. You can use the {{now}} smart value in your comment text to dynamically show the current date and time whenever the comment is added.
👉 For example: You create an automation rule that looks for certain text in new comments on work, then acts if it finds that text. In the condition for that rule, you can use the {{triggerIssue.comment.body}} smart value, which is a combination of the {{triggerIssue}} and {{comment.body}} smart values.
Let's explore an example
👇Click the boxes below to explore how Danika should build her automation rules.
Create branches within an automation rule
A branch acts as an independent sub-rule within an automation rule. It runs conditions and actions on multiple related work items. Branches are optional. You can use multiple branches in a rule.
👉 For example: In Jira, you want to create an automation rule that identifies when a work item has a new comment, then adds that same comment to their parent epic. You start by configuring the main automation rule with the Work item commented trigger and a JQL condition with this JQL:
"parent" is not EMPTY
Then, you’d configure the branch rule by selecting Add a branch. There are different kinds of branch rules available.
When would you use branch rules?
Branch rules extend the power of automation rules. Let’s explore several use cases for them.
👉 First example: You decide that all stories within your space should have a parent epic. You can create an automation rule that automatically adds comments to all work items in the space that violate this policy. This will notify all watchers of the work items.
How was this lesson?
next lesson
Best practices for managing automation rules
- Manage automation rules
- Troubleshoot automation rules
