This morning I installed RMsis (same mysql database server as Jira, but separate database). A colleague worked with RMsis without issues.
I then imported a project from an external bugzilla. During the import, I received a warning that Jira was unstable (see attachment). Stopping and staring Jira cured this issue (running on 64-bit ubuntu 12.04).
Jira then went down, and refused to start. I had to remove the PID file (even though I changed the owner of the directories to jira) and kill the still running jira process. A restart resulted in the error message below.
I have verified that I can log into mysql (mysql -u jirrauser -p) from the command line.
I have increased the values for the connection pool from 20 to 50 (what should I set them to?).
I have upgraded Jira from 5.1.5 to 5.1.8.
Still the same result. Google was no friend, although I found one issue that appeared closely related, but without a resolution:
https://jira.atlassian.com/browse/JRA-27348?page=com.atlassian.bonfire.plugin:jira5compat-bonfire-ts-issue-tabpanel
2012-11-07 13:45:58,862 main INFO jira.config.database.DatabaseConfigurationManagerImpl Now running Database Checklist Launcher
2012-11-07 13:45:59,084 main ERROR NoModule Error getting datasource via DBCP: JdbcDatasourceInfo{uri='jdbc:mysql://127.0.0.1:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB', driverClassName='com.mysql.jdbc.Driver', username='jirauser', password='********', isolationLevel='null', connectionProperties=null, connectionPoolInfo=ConnectionPoolInfo{maxSize=50, minSize=50, initialSize=null, maxIdle=50, maxWait=30000, sleepTime=300000, lifeTime=600000, deadLockMaxWait=600000, deadLockRetryWait=10000, validationQuery='select 1', minEvictableTimeMillis=60000, timeBetweenEvictionRunsMillis=300000, poolPreparedStatements=null, testOnBorrow=null, testOnReturn=null, testWhileIdle=true, maxOpenPreparedStatements=null, numTestsPerEvictionRun=null, removeAbandonedTimeout=300, validationQueryTimeout=3, defaultCatalog=null}}
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Access denied for user 'jirauser'@'localhost' (using password: YES))
at org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1549)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1388)
at org.apache.commons.dbcp.BasicDataSource.setLogWriter(BasicDataSource.java:1134)
at org.ofbiz.core.entity.transaction.DBCPConnectionFactory.getConnection(DBCPConnectionFactory.java:109)
at org.ofbiz.core.entity.ConnectionFactory.tryGenericConnectionSources(ConnectionFactory.java:69)
at org.ofbiz.core.entity.transaction.JNDIFactory.getConnection(JNDIFactory.java:146)
at org.ofbiz.core.entity.TransactionFactory.getConnection(TransactionFactory.java:101)
at org.ofbiz.core.entity.ConnectionFactory.getConnection(ConnectionFactory.java:59)
at com.atlassian.jira.ofbiz.DefaultOfBizConnectionFactory.getConnection(DefaultOfBizConnectionFactory.java:28)
at com.atlassian.jira.upgrade.util.UpgradeUtils.tableExists(UpgradeUtils.java:101)
at com.atlassian.jira.appconsistency.db.MinimumUpgradableVersionCheck.databaseSetup(MinimumUpgradableVersionCheck.java:49)
at com.atlassian.jira.appconsistency.db.MinimumUpgradableVersionCheck.isOk(MinimumUpgradableVersionCheck.java:30)
at com.atlassian.jira.startup.JiraDatabaseConfigChecklist.doStartupChecks(JiraDatabaseConfigChecklist.java:63)
at com.atlassian.jira.startup.JiraDatabaseConfigChecklist.startupOK(JiraDatabaseConfigChecklist.java:51)
at com.atlassian.jira.startup.DatabaseChecklistLauncher.start(DatabaseChecklistLauncher.java:35)
at com.atlassian.jira.startup.DefaultJiraLauncher$2.run(DefaultJiraLauncher.java:92)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:284)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseConfigured(DatabaseConfigurationManagerImpl.java:175)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:87)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:25)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:62)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:57)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:76)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:71)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:104) <+12> (StandardContext.java:4206) (StandardContext.java:4705) (ContainerBase.java:1057) (StandardHost.java:840) (ContainerBase.java:1057) (StandardEngine.java:463) (StandardService.java:525) (StandardServer.java:754) (Catalina.java:595)
at java.lang.reflect.Method.invoke(Unknown Source) <+2> (Bootstrap.java:289) (Bootstrap.java:414)
Caused by: java.sql.SQLException: Access denied for user 'jirauser'@'localhost' (using password: YES)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1055)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:956)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3558)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3490)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:919) <+2>
at com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:1284)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2142)
at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:781)
at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:46) <+3>
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:352)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:284)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1556)
at org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1545)
... 47 more
2012-11-07 13:45:59,103 main ERROR atlassian.jira.startup.LauncherContextListener Unable to start JIRA.
com.atlassian.jira.exception.DataAccessException: java.sql.SQLException: Access denied for user 'jirauser'@'localhost' (using password: YES)
at com.atlassian.jira.upgrade.util.UpgradeUtils.tableExists(UpgradeUtils.java:128)
at java.sql.DriverManager.getConnection(Unknown Source)
at org.ofbiz.core.entity.ConnectionFactory.tryGenericConnectionSources(ConnectionFactory.java:87)
... 38 more
