I have created a script which should create an issue. Target WF has validators on the create screen and I receive error "Field X is required". Validator come from Suite Uilities. I'm setting Field X via custom_field_mappings but it looks like they are used after validators stage. Anyone successfully created an issue with validators enabled using SIL?
I have found the solution.
If you pass the parameter custom_fields_mapping don't use syntax from documentation that is:
{custom_fields_mapping}
use simple:
